WD stuck in 4th gear
Bigsprings 45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigsprings 45 Quote  Post ReplyReply Direct Link To This Post Topic: WD stuck in 4th gear
    Posted: 26 Sep 2019 at 8:18pm
Can someone explaine to me how to fix this.
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 12:24pm
Broken fork?  Take apart and inspect the shifter assy.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 5:04pm
basically, what 'Twins said. you have to start by removing the shift tower. likely all you will need to do is realign the forks. Not unheard of for the forks to get out of alignment one worn transmissions with a little 'ham fisted' shifting. I have one that will get into two gears at once if I get rough with it. I learned to be gentle and have not had an issue since.
I am still confident of this;
Wait for the Lord;
