18.4 X 28 Tires for 6070 |
rieg
Topic: 18.4 X 28 Tires for 6070Posted: 25 Sep 2019 at 9:28pm |
I am looking for a set for a 6070 haying tractor. An off brand would be fine, don't want to spend a lot. Any recommendations would be welcome.
rieg
WNYBill
Posted: 26 Sep 2019 at 7:46am |
Good luck! I am watching this post with intrest. Changing to 30 inch wheels or go back to 16.9x28, may be the best solution.
Edited by WNYBill - 26 Sep 2019 at 7:48am |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 26 Sep 2019 at 9:13am |
Most 6070 tractors came with 16.9 34 tires. 18.4 28 tires are way too short, about 7 1/2 in dia. 18.4 30 tires are around 2 1/2 inches shorter.
DrAllis
Posted: 26 Sep 2019 at 9:15am |
Find a dealer that sells BKT brand tires. They are usually cheaper and I've had good luck with them.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 26 Sep 2019 at 9:53am |
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 26 Sep 2019 at 8:35pm |
1) Those tires are way too small one of 6080’s run 16.9x38’s the other two 18.4x34.
2) You get what you pay for in tires I’ve bought cheap tires and got cheap crappy tires. Buy Firestones and have something decent. |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7643 |
Posted: 26 Sep 2019 at 8:52pm |
New tires are expensive to buy, but you will not need to replace them in 2 or 3 years if you go with used tires. |
Dave Wisc.
Posted: 27 Sep 2019 at 5:24pm |
I got a set of 18.4x34 not great but good tired and no breaks.
rieg
Posted: 29 Sep 2019 at 7:27am |
Thanks guys my 6070 is fwa and the front tires are 11.2 X 24 so I think I am going to have to keep the 18.4 X 28. The tires on it now are weird 18.4 X 15-28 the rim measures 17 outside to outside and 15 3/4 inside bead to inside bead. Alliance brand any suggestions? Thanks
rieg
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4285 |
Posted: 29 Sep 2019 at 8:28am |
rieg; 15x28 is the old designation that became 18.4x28. Some manufacturers, (maybe all) put both on tires for a time. Now they are switching over to metric measurements and I'm seeing something like 480x38, replaces 18.4x38.
victoryallis
Posted: 29 Sep 2019 at 11:14am |
Put Alliance on my 6080 ran them roughly 3 years they cracked like crazy took them off and put Firestone on much happier. Firestone also has better grip. |
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Posted: 30 Sep 2019 at 6:04am |
BKT and Alliance are comparable. The TR135 is a cheap tire, you get into the radials on both and the quality is way better on both brands. I was selling Alliance 20.8 radials $600 per tire cheaper than Firestone’s.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5282 |
Posted: 30 Sep 2019 at 8:58am |
I have a pair of 18.4X28 Firestones that I’d sell. I’m in Maryland, very near Gettysburg, Pa.
rieg
Posted: 30 Sep 2019 at 9:06pm |
Tempting Paul, pm me lets see what you have.
rieg
Missouri TOM
Joined: 02 Oct 2019 Location: Clarksville Mo. Points: 29 |
Posted: 02 Oct 2019 at 2:33pm |
I had to buy one for my 6080 and "ADVANCE" was the cheapest one i could find and it was $600.00 and seems to be a good tire.
