190XT Diesel Weight |
55WD45d
Topic: 190XT Diesel WeightPosted: 18 Sep 2019 at 9:55am |
What weight can a 190XT Diesel be brought down to with out major modifications? I am mainly looking at putting pressed steel wheels on the back and unbolting/ removing unnecessary parts ( 3 point...etc) for tractor pulling. I want to run it in the farm stock class so I can't get too crazy. Thanks
DougG
Posted: 18 Sep 2019 at 6:55pm |
Had a 200 like this that your wanting to do with, got it to 8700 easy, but had 3 pt etc on it,, with your ideas, pressed steel , no 3 pt prolly around 7500, put a hollow front end box on it looses 400 lbs
DrAllis
Posted: 18 Sep 2019 at 9:19pm |
Helped a customer years ago with a cabless 190XT S-3 with 18.4 x 38's with cast iron centers, no weights or fluid anywhere and I think the 3 point was still on it and he pulled it in the 9,000 lbs class at 125 HP.
Edited by DrAllis - 18 Sep 2019 at 9:19pm |
DougG
Posted: 18 Sep 2019 at 9:51pm |
That's where the ole 200 was
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 810 |
Posted: 19 Sep 2019 at 8:13am |
You should be able to get one down to less than 7000lbs. I do know of a gasser unit in our area that is below 5750, lighter rear end and engine, though. I am building one for a 7000lb super light mod farm class.
Acllss puller
Posted: 26 Sep 2019 at 2:24pm |
I’m building new rails for mine so I have aluminum frame rails and light steel front end available rails appear stock and are solid they are good pieces
55WD45d
Posted: 26 Sep 2019 at 3:28pm |
Thanks for the information. I might have more questions if I decide to go ahead with the project. ![]() Thanks again
