how not to change oil
D17Milo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17Milo Quote  Post ReplyReply Direct Link To This Post Topic: how not to change oil
    Posted: 16 Sep 2019 at 9:28pm
So dumb I thought I would share it. Went to change oil in my 170 and had trouble getting the drain plug loose. Thought I would crack it loose with my impact, almost all the oil ended up on the floor. Don't think I'll try that again.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 6:04am
Thanks for sharing.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 6:47am
Oops!  Any end up splattered in your face?LOL
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 6:47am
Lesson to be learned: Buy some proper fitting copper compression washers and don't tighten the plug so tightly.
Edited by DougS - 17 Sep 2019 at 6:48am
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 7:13am
On so many offroad forums that I used to frequent, my "given" name was, "Torque Anal." I guess I AM just that; my thinking? IF THERE'S A PUBLISHED TORQUE VALUE, THERE'S A REASON FOR IT, SO USE IT!!!
Sort of tight, tight enough, tight as you can get it - are not proper values. And WILL cause trouble. I never start, or end, a project without my torque wrench(es) there the whole time.
Case in point: Lug nuts on autos with disc brakes. Too tight, rotors can warp, leading to premature replacement. Torqued properly, maximum brake life. WHO KNEW? lol! Anyways, I've crossed the "DO NOT HIJACK THE THREAD" line, sorry!
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 7:53am
Now that there is funny.
Kudoes to you for sharing, not everyone will admit to doing something silly.
Leon B Mo
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 9:07am
It's nice they put such a large drain plug on there, gets the oil out fast.😆
My DA put a 5 quart pan under the one-seventy the first time I changed the oil.........won't do that again.😆
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 9:10am
Sounds like something I did.
New to me truck and I needed to change the oil.
Got 2 gal oil and a filter.
Put a 2 gal drain pan under the truck and watched 15qt drain out.
That's 7qt on the floor.
Then it was back to town for more oil so I could move the truck.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 9:16am
However you loosen the drain plug you need a container under the drain plug big enough to hold all the crank case content before you loosen and remove the plug. Don't drop the drain plug into that container.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 9:25am
How to change oil.
1- Put too small of pan under drain plug.
2- use vise grips to remove plug
3- drop plug in to drain pan as oil runs down your arm
4- watch oil overflow drain pan on to floor
5- go have a beer before you clean up the mess
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 11:14am
Step 6, tighten to 180 ft-lbs for the next time
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 11:24am
I saw a 'professional' heavy equipment mechanic( he always bragged..) ,toss 10 gallons of oil into a bulldozer THEN figured out WHERE the RIVER of oil was coming from......
..drain plug was next to phone...hmmmmm
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 11:33am
I forgot a step.
It is very important that you don't check to see if the gasket from the old filter is still on the block.
Two gasket are always better than one.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 11:45am
Gerald J.
Wink I thought that was the reason to have a long handled magnet,  Confused real close when changing oil.LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 11:55am
Originally posted by cabinhollow cabinhollow wrote:
I forgot a step.
Naturally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 12:06pm
The only tools needed to remove the old oil filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 12:27pm
That's 90% of my tools. Wink
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 1:25pm
How to change oil.
There's a step that sometimes subs in for step 3....... drop plugs and watch it roll away just out of reach as you stick your finger in the drain hole to stop flow and you think to yourself.... now what.
Happens only when you do not intend to drain the oil but just check for water.
Wink
I am a Russian Bot
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 7:46pm
Lonn. I didn't realise you were watching me change oil!? That list looks just like what I do on the first tractor at my fall oil change extravaganza. She's a pretty toney event after I get done painting the floor with used motor oil.
Edited by Reindeer - 17 Sep 2019 at 7:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 8:45pm
Get the whole how to change the oil story, here...
As for spillin oil, I always liked the ad AAMCO transmission had where the mechanic pulls the plug and takes an oil bath.  Can't find it on youtube, maybe it was another company's ad...Wink
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 9:28pm
Good story Dave, except number 8 would be aaaah hell have another, do it tomorrow. Lol
