burning points...D17
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: burning points...D17
    Posted: 16 Sep 2019 at 6:35pm
Okay, I need some help,
 I have been fighting this D17 for a long time, previous owner bought it and put new points in and I cleaned them up numerous times... then I got it from him and run it maybe 3 hours or less and it starts stutterin and missing and numerous other maladies.... Changed them and condenser several times and I just put new points in from Napa and they did not have a new condenser to sell me... so I dropped the points in and was happy for a couple hours and back to missing etc... took new points out and had to clean them up.... coil won't fire without condenser, and got good spark at the high tension terminal with condenser, but... as lots spark at points... Coil is a Delco Remy 12 volt and I think it has a 73 on the side of it.... I see no resistor in the system, did they have a resistor wire going to the coil? or did the coil have a resister in them?
Somebody had put a new wire in between switch and coil...
  Thanks for any help with this problem.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 6:55pm
Try a different coil. Measure across the coil terminals and see if you have about 3 ohms. Some coils say "12 volts with resistor." It's a clever way of disguising what's really a 6 volt coil.
Edited by DougS - 16 Sep 2019 at 6:56pm
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 7:32pm
Convert it to electronic ignition. Did our D17 IV years ago and never looked back! Runs great all the time. Little over $100 and 15 minutes of work.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 7:32pm
12 volt systems on automotive run on 6 volts for points but 12 volts to start. To do that an external resistor is used or resistor wire(GM cars). But they start on 12 volts so you have wire from solenoid to accomplish that. So two wires on positive side of coil. The 12 volts is only when starter is cranking. Is your system positive or negative ground?
Edited by Ed (Ont) - 16 Sep 2019 at 8:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 7:39pm
Back in the good old days of racing before we had good ignition systems we ran the points on 12 volts but installed new points every weekend. Probably a bit better quality points in those days. As already stated change to electronic. Phone Steve at B&B.
Edited by Ed (Ont) - 16 Sep 2019 at 7:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 8:14pm
What series D17 is it?        MACK
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 9:06pm
I'd almost bet you need a different coil.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 9:16pm
I bought a WD45 that was real hard on points. Had a 12 volt coil on its aid so right on the coil. Eventually I gave up and pulled the coil put a new on on. When I wiped the dirt of that was under the mounting band in small print it said external resistor required. My Corvette has one of those coils on it when you start it 12 volts goes from the starter solenoid to the coil. When you release the start switch. Power comes from the ingnition switch thru a ballast resistor to the coil. If you get the coil from a 57 Chevy that's what your going to get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 9:42pm
Mack, I believe its a 1961 model.
 Ed, it still is positive grounded... Been thinking of putting an alternator on it pretty soon and turning it to negative but... I should look to see if the coil is wired right.
Stan and Ed, I have thought about changing it over to electronic ignition, but I have been able to take care of all of these old tractors with points for the last 50 plus years, but this one got me stumped... was going to change coils from another D17 and see if that helps... and maybe the condenser too.
Doug, I will have to check to see if there's 3 ohms across the coil.
 Tom, maybe... we will see if a different coil is needed.
Dave, lots of them old chevies were that way  and so were some allis's....   My uncle told of having an old Plymouth that was the cheapest thing around... and it wouldn't start in the winter at all... He looked at it long enough and realized the company never put a solenoid on with a hot wire to the coil. So he put a different solenoid on and another wire to the coil and it would start anytime in the winter after that.LOL
  Some things to look at. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 5:29am
burning p[oints  means too much current through them. easy test.with points open, put ammeter between points stud on disti and gnd. With key on, you should read about 4 amps. If higher, you need a ballast resistor, typically 1.5 ohms, 50 watt value.
hay DD, all my '67 Mustangs all had the 'full power' to coil for starting setup......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 5:56am
Correct me if I'm wrong. Didn't they D17 gas model have a set of contacts on the starter solenoid that shorted across the resistor when the starter was cranking? Who knows how that all may have been changed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 7:18am
That D17 should've had the same setup as the old Chevy's & Mopars had like the guys mentioned. The only difference between the two was GM used a resistor wire that ran in the harness, where Mopar ran the external ballast resistor on the firewall. I saved many damsels in distress at the local supermarket back in the sixties on rainy days cause there Duster or Scamp wouldn't start! When in the crank mode, 12V's is supplied to the coil till the key is let go. Once out of the crank mode, and into ignition mode, current then ran through a ballast resistor to the points. I have an original D17 harness that I use for a pattern to build my new harnesses from, and that has a ballast resistor in the OEM wiring system. It sounds like the Ballast resistor was removed at sometime and that's why you don't get any longevity out of the points JC. What I would do is pick yourself up a new coil (12V/3.0 ohm) with a built-in resistor. This way Mother Nature can't play havoc with the external resistor (like it did in the old Mopars) toss a real set of points and condenser in it like the SMP Blue Streak brand, and let r' rip!  We have all of that in stock if interested, or you can go locally and find a Blue Streak dealer to get everything ya need.  HTH    BTW, Ed thanks for the mention....! Its appreciated!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 7:54am
My '67 Cougar had it setup that way too. They used a piece of resistance wire, like GM.   Either pick up a good "real" 12 volt coil from an auto parts store or order an electronic ignition module and pair it with a high performance coil. I'd recommend that you switch to negative ground before going to solid state ignition, though.
Edited by DougS - 17 Sep 2019 at 7:56am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 9:10am
My '68 gas 4020 had the resistance wire in the harness going to the coil and an extra contact on the starter solenoid to supply full battery voltage to the coil while cranking. The resistance wire went bad and somebody replaced it with a fixed ballast resistor and the wiring near the ignition switch went bad. When fixed it started fine and worked all day on the coil without overheating it.
Gerald J.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 10:53am
Just wanted to mention that electronic ignition kits come specific to positive ground or negative ground. I put a positive ground one on my D15. Works great. Make sure you get the polarity right when buying and installing them. Pertronix advised me that reversing the polarity might let the smoke out. Quick way to burn up a hundred bucks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 11:57am
Dave is correct. If you're going to change to Neg. Grd., you want a Neg Grd E.I.  Make sure you run resistor/carbon core spark plug wires also when using an E.I.  Solid core wires could spike the electronic module and take it right out. Also to, when charging the Battery in the Tractor, disconnect one cable (doesn't matter which one) before you charge the Battery. Just eliminates possibly blowning the module out while in charge or boost mode. I've had customer's jump up on their Tractors to fire em' up only to have a dead Battery. They hop off and would forget to shut the key off, grab their Battery booster and put a super boost into the Battery only to take out the E.I. along with it cause' the key was left on. That's another way how to throw a little over 100 bucks out the window. E.I.'s are great. You just need to be careful and not forgetful to keep em' in service. We keep all the different E.I.'s in stock if interested.....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 2:49pm
Steve, When you talk about putting a 3 ohm internal resister coil on the tractor, In cold weather, do these coils have the ability to supply full voltage to the coil and switch back to 3 ohms when they start?   Or is it like just 3 ohms supplied summer and winter for starting...?
 My 170 has external resister and it has been on it since it was new and still going strong... where as the solenoid is getting old and had to have it's connections cleaned a numerous times and needs replacing and I can not find a reasonable priced genuine Delco Remy solenoid anymore with the two lugs.  Angry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 3:40pm
It will work fine with a coil with an internal resistor, JC. Of course you'll want to keep the tractor tuned up with good plugs and wires in addition to the points, condenser, rotor and distributor cap. This would be true for any gasoline tractor, with or without a 12 volt internally ballasted coil. BTW, it would cost very little to switch to negative ground if you have a generator. No need to change to an alternator. Your biggest expense might be to buy new battery cables with the properly sized positive and negative terminals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 12:02am
Update... With cleaned up Napa $19 dollar points, used less than three hours and a new Blue Streak condenser, 14 bucks at O'rielly, and an old 3 ohm resistor that was laying around from a '66 Buick that got plumbed into the system and now hardly a spark at the points, the tractor ran real good today. From the time I turned the key on to the time I shut it off.   It is the first time it has ran this long without starting to act up.
  Thanks fellows for all the input.
mmm, got me to thinking today why did Allis switch from one wire to the coil and went to the two post solenoid and resister in line on the D17 series IV and newer... series IV had live hydraulics and took more out of the battery to turn that and I bet they went to the external so they could make a hotter spark to start in the dead of winter.
 Doug, I don't know, but it seems the old regulators use to be polarity marked.... and the new regulators don't seem to care what polarity they get hooked up +/- to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 9:48am
Most old regulators I've seem were labeled "A" "F" and "BAT". Occasionally I've seen a fourth terminal that goes to the light switch. I've not seen a polarity marking unless your regulator happens to have been upgraded to a solid state job. If you have it working now the way yo want, leave good enough alone. Beware of getting water on that resistor when it's hot. I mean they get very hot. A splash of cold water on a hot component may cause it to crack.
This page was generated in 0.135 seconds.
