wc manifold gasket?
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: wc manifold gasket?
    Posted: 09 Sep 2019 at 9:36am
Does anyone know if the gasket that goes between the manifold and the side cover with the side exit exhaust pipe is still available or if there ever was a gasket there. Agco parts book doesn't show one.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2019 at 10:13am
Probably just steel on steel.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2019 at 10:37am
Kinda what I was thinking but wasn't sure.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2019 at 10:44am
it is steel on steel, if you have a leak (I did) you can have it "faced" on a mill or flywheel grinder so you have two good flat edges
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
This page was generated in 0.172 seconds.
