Wd45 final drive , help
Chris View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 final drive , help
    Posted: 08 Sep 2019 at 5:09pm
Outer hearing on pinion shaft is bad.I read to take brake drum out.Do you have to take big gear out of final drive to do all this?can you take the 8 bolts that hold final drive housing on and get bearing out?
Thanks,
This page was generated in 0.057 seconds.
