D15 ALLIS
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: D15 ALLIS
    Posted: 01 Sep 2019 at 8:58pm
Anyone know what makes a D15 starter lock up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 9:11pm
pull the starter motor off and rotate the engine by hand... test the starter motor separate on the bench with a battery........ I had a "B" lock up a few years ago and had to remove the starter... found nothing, lubed the bendix area and reassembled... I assume the bendix was STUCK in the out position
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 11:52pm
A badly worn ring gear will do that and a worn out starter drive Bendix.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 6:19am
My D 15 wouldn't turn over with the starter . Bendix was pretty chewed up. Steve rebuilt it and it's working fine now . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 11:47am
Thank you for the information guys very much appreciated.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 12:20pm
Not a D15 but I had an Oliver 99 that the starter would lock up if a battery with poor
starting power was put in it.
