C vs. CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: C vs. CA
    Posted: 30 Aug 2019 at 7:59pm
I was reading the newest Antique Power this morning and saw this ill informed opinion printed. Seems there should be a delete button for Facts that aren't facts when they are printed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 8:07pm
why would Antique Power publish something like that without Checking first ?? ......... and you wonder where some idiots get their info.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 8:18pm
Evidently opinion overrules facts anymore.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 8:37pm
Wacko That's absurd....
I do wonder what the "A" in CA really designates.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 9:53pm
I saw that letter yesterday.  Was thinking someone should write a letter back.  I have a CA just like the one in the picture.  Other then the 4 speed and 2d clutch, what differences are there between a C and CA?
Creston, the A stands for AWESOME!
Edited by JohnCO - 30 Aug 2019 at 9:54pm
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 10:00pm
Haha, good one, John!
CA also has power shift rear wheels.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 10:05pm
Just send Rick an e-mail pointing out the correct info.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 4:47am
Snap coupler available on CA too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 5:30am
My CA had a TB guage on the steering column.. it was a '51 I think, had it been a '53 it'd still be here.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 7:27am
So if I had an adjustable width front end on my B it would be considered a BA, and if I put duallys on the rear also then it's considered a BAD tractor. That's BS or dare I say it "Fake News". LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 10:10am
I sent a message right away on facebook and got a reply that the editor would be notified.
 The differences that i can think of are, the tapped bosses in the front pedestal , tapped bosses on the torque tube, Platform under the drivers pan seat, 4 piston(WD) hydraulic pump with Traction boost,(not all CA's had the Snap Couple or TB gauge), magneto only the first couple years of production, power shift rear wheels with different bolt pattern than the C, higher RPM, option of a hand clutch on one rear axle, and what am I forgetting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 11:08am
Four forward gears.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 11:52am
The fellow might have see a CA with a narrow front from a C. No difference other than the above stated cultivator bosses. I put a CA narrow front on my C I pulled with to use the bosses to mount weight out front. Think about all the C's that confuse people that have B wide fronts. Not everyone reads these boards as we all do.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 1:10pm
The shop manual that covers G, B, C, and CA will show some factory differences:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 8:23pm
‘Course there’s the fact that the CA replaced the C and they were never manufactured at the same time....that little detail.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 9:47pm
the final drives on a B and C are bolted on straight up and down with respect to the bolt pattern......... Seems like the CA they are tilted back slightly to give it a longer wheel base ?  Or did I dream that ?  Have not seen a CA for several years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 12:17pm
The bolt pattern is the same for all three. The final drive casting is what sets the rear axles back.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 12:45am
I used to have a CA single front.  Would that be a CS?
Edited by Jordan(OH) - 02 Sep 2019 at 12:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 6:50am
WF, NF, single wheel. They were all called a CA. Unlike another tractor manufacturer, AC didn't nit pik names for the same tractor with slightly different options.
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2019 at 8:23am
I read that there were 10 improvements in model CA over model C: 1-increased HP, 2- improved hydraulics, 3-four speed transmission, 4-heavier axle, 5-draft control, 6-seat shocks, 7-improved hitch, 8-hand clutch, 9-live PTO, 10-spin out wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2019 at 8:32am
So that would mean you have a CAHPIH4SPHADCSSIHHCLPTOSOW, now put that on the tranny before the serial number. Wink
