426 head removal
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 426 head removal
    Posted: 29 Aug 2019 at 5:57pm
OK guys I need my memory freshened up some on
removing the head on a 3700 motor.
I replaced a couple of sleeves and pistons back in the
90's but that's been a while.
What sequence do you use to remove the head bolts for example.
Will a 3500 head and a 3700 head both fit on the same block.
And what about swapping the front covers also,will the 3500 water pump
circulate enough coolant to keep the 3700 cool or would I need to use
the 3700 water pump.
Thanks guys.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 7:00pm
Usually you loosen/remove the bolts is the opposite way you install them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 11:06am
i put a 7040 head on my 220 30yrs ago. Direct fit
