Octaine fuel ?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Octaine fuel ?
    Posted: 29 Aug 2019 at 12:35pm
What Octane fuel is needed to support 175 PSI cylinder pressure ?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 1:23pm
as a rule of thumb - excluding modified cams, a 10:1 CR would be approx. 150 PSI... so you have 12:1 CR ?  IF so, assuming a tractor engine since posted here  and  a low RPM engine you are going to lug, about as high as you can find?    E85 or aviation fuel....   most engines with high CR 's in automotive use have knock sensors to retard timing.  Be careful.... IMHO
Edited by tbran - 29 Aug 2019 at 1:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 1:39pm
That kind of compression is the exactly same as a 170/175 tractor and 87 octane is minimum and timing cannot exceed 25 degrees BTDC at full throttle. In fact 23 degrees BTDC is probably better. You'd do yourself a favor running 89 octane.
Edited by DrAllis - 29 Aug 2019 at 1:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 5:01pm
Thanks for the info.....
I had been running 100 octane low lead Avgas but its not always convenient to get.
Thanks again.
This page was generated in 0.045 seconds.
