7060 hesitation issue
KansRustbuzzard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KansRustbuzzard Quote  Post ReplyReply Direct Link To This Post Topic: 7060 hesitation issue
    Posted: 26 Aug 2019 at 10:26am
Hi, I have a maroon belly 7060 with the 5 speed, power director and hi-low set up. It has developed a problem when you let out on the clutch at an idle, it has a soft mushy take off like something is slipping. If you give it throttle at about 1800 it straightens out and runs fine with no issues at all. In the field, if you throttle back at the end to turn around, it does the same hesitation like its out of fluid but its not, I drained and changed the filter and looked for the obvious problems.  Also, there are no sounds or smells or anything else out of the ordinary, Any help would be much appreciated. Thanks
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2019 at 11:21pm
did you clean the screen when you changed trans oil?
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
