Repowered 720 Oil light coming on |
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2693 |
Topic: Repowered 720 Oil light coming onPosted: 18 Aug 2019 at 10:11am |
My 720 has been repowered with a Kohler, 20hp engine. After running for approximately 10 minutes or so the oil light comes on, don't hear any difference in the engine, if I shut it off and restart it, light goes out and will not come back on for another 5 to 10 minutes and the process can be repeated. How does the sending unit function on these engines, does it sense oil level or what?
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 18 Aug 2019 at 11:08am |
Does your Kohler have an oil filter? That would indicate if it were splash lubed or full flow oiling.
Either way I'd check for a loose wire on the sending unit or a bare spot on said wire.
Edited by exSW - 18 Aug 2019 at 11:10am |
JW in MO
Posted: 18 Aug 2019 at 11:47am |
It has an oil filter.
exSW
Posted: 18 Aug 2019 at 12:34pm |
On my Magnum 18 the port for the oil sending unit is right above the filter.
Edited by exSW - 18 Aug 2019 at 12:35pm |
