Allis chalmers b final drive |
Levibridge95
Joined: 23 Jan 2018 Location: Quakertown Pa Points: 69 |
Topic: Allis chalmers b final drivePosted: 17 Aug 2019 at 9:10pm |
Hey. I'm a new member here and I'm currently rebuilding a '51 AC B. I broke my left final drive trying to remove the shaft to replace bearings. I have a spare one I'm buying to replace it. Any tips on removing the shaft without breaking the final drive casing? Which way do you press? Thanks.
Jim.ME
Posted: 17 Aug 2019 at 9:26pm |
Welcome to the forum.
Which shaft were you trying to pull, pinion or axle? I expect Gerald will post a link to the manual (it covers the G, B, C, and CA models) he has on line, when he sees your post. Down load and save a copy so you have it. That will give you the info you need and the tools to do the job. Easier if you read it first. Folks here will give you a hand if you have questions about the procedure. |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 17 Aug 2019 at 9:44pm |
the bull shaft comes out pretty easy after the remove the snap ring on the bull gear / shaft.... the top axle shaft is really not stuck in the case, it is "normally" the brake hub that is stuck to the shaft... There is a lock screw on the hub.. access thru the 1 inch round hole in the case.. You might head the brake hub.. soak with penetrant, etc... Many are HARD to get off. some have broken the brake drum to get the shaft out. I have never heard of the CASE breaking... I set the base on the end with shaft sticking straight up.. press the shaft OUT from the INSIDE to the OUTSIDE ... and it moves thru the drum as you push........ service manual shows a puller with rods you connect to the drum, then portapower the shaft thru ........ I have also beat them out with a 5 pound hammer and brass plate, but you can distort the splines that slide into the differential if you pound too much...... small grinder can then fix it up.
Levibridge95
Posted: 17 Aug 2019 at 9:50pm |
Ok thanks. Maybe that's where I went wrong. Instead of pressing inside out, I went outside in thinking it would work. I have the hub stuck on the other final drive axle that i can't get off. It has the one big nut in the middle. Any ideas?
Jim.ME
Posted: 18 Aug 2019 at 5:38am |
Here is a link to the factory service manual. You can down load and save it. It is in sections for the different tractors. You need to review pages 36 through 38 in the B, C section for this project. That will help you with nomenclature and sequence. Do you have the final off the tractor? Be sure you tell which shaft, etc. you are working on. Folks will help you with your questions from there.
G, B, C, CA service manual |
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 18 Aug 2019 at 7:07am |
Dick L
Posted: 18 Aug 2019 at 7:47am |
You might want to tell exactly how and where the final drive broke. What all lock screws and nuts you had removed would also help us help you.
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 18 Aug 2019 at 11:37am |
The shop manual link I have is:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
Levibridge95
Posted: 18 Aug 2019 at 12:43pm |
It was the pinion shaft. I removed all the bolts and nuts. It broke on the inside part between the brake drum and the gear. That bearing in the middle. Thanks for the help so far.
Dick L
Posted: 18 Aug 2019 at 3:07pm |
Were you pressing on the spline shaft that goes into the transmission?
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 18 Aug 2019 at 3:12pm |
Levibridge95, Welcome the the Unofficial Allis-Chalmers Forum. As shown above you will receive a warm welcome and LOTS of outstanding help. I cannot add to what has already been said only to say, Take good care of my favorite Allis Chalmers Tractor. Sounds like you are doing a GREAT JOB! Good Luck! Bill Long
steve(ill)
Posted: 18 Aug 2019 at 4:42pm |
Ok thanks. Maybe that's where I went wrong. Instead of pressing inside out, I went outside in thinking it would work. I have the hub stuck on the other final drive axle that i can't get off. It has the one big nut in the middle. Any ideas? Edited by steve(ill) - 18 Aug 2019 at 4:53pm |
steve(ill)
Posted: 18 Aug 2019 at 4:49pm |
Set the axle housing in the press or on a couple of wood blocks so it is LEVEL and the differential end ( splined shaft) pointing UP... See DICKS picture of the press... The press is the way to go.. You can BEAT it out, but check splines for minor distortion after the shaft is out... You are trying to push the shaft THRU the brake drum... There is a SET SCREW in the hub !! get it out first... Soak with penetrant... maybe some heat.
Levibridge95
Posted: 18 Aug 2019 at 8:51pm |
Yes
Levibridge95
Posted: 18 Aug 2019 at 8:52pm |
Thank you
Levibridge95
Posted: 20 Aug 2019 at 7:05pm |
