Buda 292d engine
Wes Jackson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes Jackson Quote  Post ReplyReply Direct Link To This Post Topic: Buda 292d engine
    Posted: 17 Aug 2019 at 5:53am
I am looking for a good engine for my Fiat Allis 65 motor grader
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 8:06am
I do not believe this a Buda Engine if is the later version M65 or 65B. These were a re-engineer of the old DD series and contain a few cosmetically appearing similarities but I am fairly certain the DDs were the Allis series engines as Farm Tractors had and would expect the 65 to have a Fiat supplied engine. Any chance of Year of machine and if has a 65B designation? In 1974 they adopted a better engine for the 65s, the Fiat engines were installed after 1979.
Edited by DMiller - 17 Aug 2019 at 8:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 8:16am
I stand corrected, is a Lanova D262 series if prior to 1979. If is a D262 may wish to try for a 4BT Cummins change over or look to NORAM as to how they attached a later model CNH engine into the M65 Frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 8:22am
Mine is a model 65, I think early 70 model. What would be involved in changing over to a Cummins engine
Edited by Wes Jackson - 17 Aug 2019 at 9:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 9:50am
Will a Allis Chalmers 2900 fit this grader without a lot of mods, just weighing my options
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 10:01am
Most everything is side swapped, Fuel, Linkages etc, likely a better choice than a 4BT but would also have to find a flywheel compatible for the drive system or have one made for either. What is bad on the old engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 10:20am
Plug came out of intake and the engine sucked in about an acre of dust which ate the pistons,rings etc. Rebuild kit is 2 grand and pistons and rings are back ordered, trying to get grader up and running
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 1:08pm
Could wind up spending WELL beyond the $2k and still not be up and running. Biggest concern is flywheel design for connection to the drive transmission, cannot duplicate that on a purchase you are at the beck and call of what are deemed "Prototype" or single product machine shops. I would shop around as could and dig deeper try to find the parts to get this engine together.
Other option, go on Machinery Trader and try to locate a Pre 1979 M65 engine complete or a second machine just for yours to become a parts provider.
Edited by DMiller - 17 Aug 2019 at 1:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 3:53pm
Thanks for the help and advice.I was hoping to find a running engine but not having any luck, guess I will wait on pistons and rings and rebuild mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 3:55pm
Believe will be better off at least $$$$ wise.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 9:05pm
Would that have been the last Lanova system in production then?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 4:54pm
I am thinking so, but had the Roosa Master style Injection pump instead of the Rotary PSB.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 5:42am
I found out the head is cracked so I have decided to sell this grader and a parts machine as well, block and crank are good, trans good,all hydralic cylinders rebuilt, make offer! Located near Florence SC
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 7:04pm
you could fit a 262 gas motor pretty easy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 9:29pm
Did you get that head pressure tested?
A bloke here did up one of those motors on a DD.  Said it had head cracks but they didn't go anywhere under test so they used it.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 10:22pm
Cracks on Lanova heads are common. Both Oliver/Waukesha and Allis/Buda. They are usually not fatal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2019 at 4:46am
I got the head back from the machine shop and the cracks are hairline cracks where the injector holes are, was told this is common on these engines. I allready bought another grader so this stuff is still for sale.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 4:46pm
The Allis Chalmers Buda D262 has a Lavona combustion. I was used in D17 tractors and the M65 and DD graders among others.
This page was generated in 0.449 seconds.
