CA pin couple swap to snap couple |
| Author | ||
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2077 |
Topic: CA pin couple swap to snap couplePosted: 16 Aug 2019 at 9:11pm |
They work well but they are a little loose and pivot on the bolt. Since I have both pin & Snap-Coupler equipment I have no need to cut the arms down. One benefit to leaving the arms long is have lift snap-coupler equipment a bit higher off the ground. |
Thanks & God Bless
Dennis |
| Sponsored Links | ||
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 16 Aug 2019 at 4:52pm |
I thought the lift latches wouldn't fit right with the extra part on the bottom of the pin hitch lift arms. Edited by CTuckerNWIL - 16 Aug 2019 at 5:23pm |
DennisA (IL)
Posted: 16 Aug 2019 at 1:32pm |
Don't need to cut down the lift arms. I use mine with both pin and snap coupler implements.
Thanks & God Bless
Dennis |
Dakota Dave
Posted: 16 Aug 2019 at 10:44am |
Why not just get a pin hitch 3pt adapter. I did and it worked great. I put the pin hitch back on later. The woods belly mower dosent work with a snap couple the bell gets in the way with a pin hitch I can have a hitch with the belly mower installed. I put the pin hitch adapter on one of my WEd 45s and it workes hreat there also
rtwfarm
Joined: 26 Feb 2012 Location: nebraska Points: 1349 |
Posted: 16 Aug 2019 at 10:22am |
I have a parts ca with all the snap coupler parts. Ryan 402-469-1738
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3200 |
Posted: 16 Aug 2019 at 10:20am |
I'd personally like the pin set up better
CTuckerNWIL
Posted: 16 Aug 2019 at 9:07am |
Yes you can add the Snap Couple bell, but you have to alter the lift arms for the proper lift latches to fit.
The pin hitch lift arms have a little "hangy down" piece with an extra hole, compared to the SC lift arms. ![]() Edited by CTuckerNWIL - 16 Aug 2019 at 9:09am |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Posted: 15 Aug 2019 at 4:52pm |
Hey welcome to another Wisconsinite. Sorry I can't answer your question but there are alot of knowledgable helpful people here. Where in WI are you?
super71bee
Posted: 15 Aug 2019 at 4:49pm |
Hi everyone. I just started on this forum as I am new to the tractor world. I have been recently given a nice running 1951 Allis Chalmers CA, serial number "CA 635". My question is, can I upgrade the pin hook up to the newer snap coupler set up from another newer model CA? I want to use the tractor to pull some simple implements for working on my small deer food plot. The hydraulics work fine as I have already tested it. I know I could buy implements that will hook up to a ball on the draw bar but they are pricey and I sort of like the idea of using original parts. Thanks for whatever help you can give me.
