What bolt grade to mount loader?
JaredC(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Topic: What bolt grade to mount loader?
    Posted: 13 Aug 2019 at 9:13am
Finally getting closer to actually mounting the old Henderson loader I got this spring on my CA. Hoses have been replaced, cylinders rebuilt and just waiting for the call saying fluid is back in my rear tires.
What grade bolts should I be using to mount the loader frame to the tractor? Thanks!
Jared
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 9:39am
Grade 5 or 8 would work well.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 9:49am
grade 5 should be overkill for the loader.... That's a good idea.. much better than the grade 2 basic stuff.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 10:16am
Grade 5 works great the original square heads were grade 2
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 10:56am
You'll never go wrong with grade 8 bolts with something like that,plus they don't
rust nearly as bad as lower grades.I rarely buy anything but grade 8.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 12:23pm
I use the 8's, then you know they are good for anything you could throw at a 2 or 5 grade on a loader mount.
Rhoadesy_65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rhoadesy_65 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 1:51pm
grade 5 will take shock loads better than grade 8. Grade 8 will snap not bend. Usually
hear use grade 5 for shock loads and grade 8 for constant loads.
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 4:32pm
I agree, 8 are too brittle for that application.  Go with 5.  Fortunatly I had the original bolts for mine, when I mounted it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 6:22pm
Grade 5 and never-seize...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 6:35pm
I've owned and seen a lot of loaders have never seen a grade 8 bolt snap off if 5 was stronger then there'd be no need for grade 8.And if sudden impact broke grade 8 so easily they'd be used for shear pins(LOL)
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 7:18pm
grade 8!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 7:19pm
Grade 8 bolts are normally for Head Bolts and Rod bolt type applications. Nothing wrong with using them for the loader, but WAY overkill..... its your money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2019 at 7:37am
Thanks, all!
This page was generated in 0.219 seconds.
