180 AC power lift arms
D21GRF View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D21GRF Quote  Post ReplyReply Direct Link To This Post Topic: 180 AC power lift arms
    Posted: 12 Aug 2019 at 2:45pm
Power lift arms in up position and can’t get them to lower even with tractor shut off..it is a 3 point hitch...any help appreciated
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 4:20pm
Check the position control linkage to see if it is in the correct position and the linkage is free. The plunger on the spool is spring loaded and operated by a cam lever,
If every thing is ok there, you may have a stuck lift cylinder. I had that problem on my 180. You can check by disconnecting the hose on one side to see if will go down.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D21GRF Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 8:52pm
Thanks Joe, I’ll check those tomorrow.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 8:58pm
There are 3 pivots in the linkage that are notorious for rusting and seizing up.  Even if one of these are seized it will affect things.  Don't move the handles, oil each pivot point and make sure each one moves easily - you may have to disconnect some of the linkage to do this.  If all of them move freely and your hydraulics do not lower, the valve is probably stuck.  It can be freed up easily by working it out with a pair of vice grips.  Been there and done this many times.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D21GRF Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2019 at 9:12pm
Found my problem ...had linkage froze up ...thanks for your help
