Allis 7020
mnjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnjoe Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7020
    Posted: 11 Aug 2019 at 8:36pm
Was planting cover crops today. I noticed an oily spot behind my square fuel filter. I can wipe the block and watch it flow. Is there a plug that is leaking???   Looking for ideas......Thanks
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 8:40pm
Probably the oil pressure sending unit.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 9:23pm
Is it oil or diesel?  We are not there to see for ourselves.  Only you can determine what it is and where it is coming from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnjoe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 9:33pm
It does not smell like diesel..feels like oil. Will get a mirror and look behind tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 9:51pm
Oil pressure sending units are known to leak.    MACK
B&C Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B&C Farms Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 10:02pm
working on my brothers 9745 trying to get the ac to work. I have power to the relay by the fun but can not get the compressor to kick in or the fan in front of the radiator to work can jump the relay and get each one to run just will not work with the relay the relay is new and pressures are 40 low side 240 on the high side any help would be great thank you
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 6:41am
9745???? Wrong forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnjoe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 4:17pm
It looks like the sending unit by feel. So what is the best way to replace it? Remove starter or fuel filter setup? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 9:28pm
Fuel filter bracket.      MACK
