HD11 4-71
BradfordTas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradfordTas Quote  Post ReplyReply Direct Link To This Post Topic: HD11 4-71
    Posted: 06 Aug 2019 at 2:34pm
G’day, I’ve got a Ali’s dozer, it’s got HD11 stamped on the plate but it has a 4-71 Engine, did they ever do this or is it most likely a hd9? And is there’s much actual size difference between the hd9 and hd11?
Cheers Brad
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 10:56am
Very little difference of a HD9 and early HD11. The big difference was using the Buda engine in the HD 11.  So no HD 11 left the factory with DD 471.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 12:20pm
probably retrofitted engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 5:34pm
We don't know what they did down under, I believe there was a plant on Oz, that built AC machinery, but their machinery and ours were not always the same.  I know Oz (serial)numbers don't match up with our numbers...Wink
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 7:36pm
Serial # stamp on rear of rear end housing, right side near the top will tell you if its HD9 with HD11 cowling with ID tag, or HD11 repowered with the Jimmy. There are a few repowers in New Zealand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradfordTas Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 11:24pm
Thanks guys much appreciated
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 2:34pm
The HD11 HAVE MORE ROLLERS ON.
