Reusing Bearing Flanges
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Reusing Bearing Flanges
    Posted: 31 Jul 2019 at 5:36pm
How many of y’all reuse bearing flanges (on combines for example) and how many replace them? Been having a few interesting conversations with farmers/dealers and it seems everyone has their own different opinion.
Some say reusing them works fine, and others say they have a certain amount of “crush” to them when tightened, and are only a 1-time-use piece because of that.
Thoughts?
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 5:44pm
I used to reuse, as long as there was a tight fit. But now, with the cost of the flange, vs the cost of the bearing, vs the cost of my labor, I just replace it all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 8:38pm
Have never saw a bearing spin in a flange. With the movement of shaft with twist of machine, a little movement of bearing in flange will go along ways on the life of a bearing. Put that bearing in a bind with new flanges and bearing life is shortened.      MACK
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 10:57pm
In hard to get to areas we feel inclined to put new on, but if the old ones still grip well, and still have some nice factory paint, we usually re-use. :)
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 6:03am
Like you said,many opinions. Only if brg is floating in it. You can make one serviceable by pressing a large 12pt socket over the lip.
