roto baler belt replacement |
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 609 |
Topic: roto baler belt replacementPosted: 30 Jul 2019 at 7:22am |
Will belting cut to length with lace style connectors work when replacing belts on roto baler (take the pressure as bales develop)? If not, I see having to totally disassemble the left side to put continuous belts on - ugh! Thanks for any response or ideas
soybreedingboy77
Posted: 30 Jul 2019 at 7:33am |
Yes, as a kid I remember dad replacing with laced belts purchased at local Allis dealer.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1128 |
Posted: 30 Jul 2019 at 8:16am |
better question is where to get continuous belts?
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8781 |
Posted: 30 Jul 2019 at 8:49am |
I have ran laced belts on mine for about four years now without any problems. Only make about 3 to 5 hundred bales per year though
Darrel |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5282 |
Posted: 30 Jul 2019 at 9:40am |
Cut and spliced belts will work if they are all exactly the same length. They are just a bit noisy compared the endless ones. I have a complete NOS set of upper and lower endless belts i would consider selling. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55316 |
Posted: 30 Jul 2019 at 5:43pm |
As long as the laces are clipper type laces, they will work fine. You don't wanna use any of the more modern type laces, 'cause they are too stiff, and don't bend enough to go around the small rollers, that a roto-baler uses. Google Hammond equipment, faunsdale, (ALA?), they can cut you the proper set, if you need'em...
Dakota Dave
Posted: 30 Jul 2019 at 6:36pm |
Back in the 70s we had to replace the roto bailer belts. We had picked something up ane cut one so put a laced belt on . It worked but not as good as the endless belts. At the end of the summer we put a full set of endless belts on. At the time we baled 6000 hay and 1000 straw bales each summer.
MACK
Posted: 30 Jul 2019 at 9:23pm |
Back in the 60s I would go out after work and replace a set of endless belts for 20.00 labor, if the owner would help me set the header off and on. About 1 1/2 hr. MACK
DiyDave
Posted: 31 Jul 2019 at 4:38am |
one thing I forgot, of you are replacing laced betts, lace the new belt , to the old belt, and pull the old belt out, as you pull the new one in, saves a lot of time...
