CA temp gauge location
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Topic: CA temp gauge location
    Posted: 28 Jul 2019 at 3:48am
Hi can anyone tell me where the temp gauge and sender is supposed to be located I thought it would be the same as a B but the CA that i have doesn't have the place for it in the thermostat housing , it has the hole in the bonnet but no place for a gauge ?
thanks steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 5:37am
hmm, maybe it was replaced by previous owner ?
I'm sure my CA had one in the stat housing...well, kinda sure, um, yeah, I think so... yeah it did...
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 8:00am
All the CA's were the same as the B's and C's. That would be some clever re-engineering that was most likely cheaper than ordering the original type.
The proper place for a censer in re engineering is any place you get to the flowing water in the water jacket. I would probably drill and tap behind and below the generator.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 7:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 7:16am
Pitch the housing you have, and get the one that belongs there. Early B's didn't have a temp gauge and it looks like somebody put an early B housing on your engine.
 Image result for Allis Chalmers CA thermostat housing
Edited by CTuckerNWIL - 01 Aug 2019 at 7:19am
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 7:28am
Thanks for the reply i will start looking for one
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 12:18pm
Steve  !  If  you can`t  find one  down under  drop  me  an  E mail.  I have  some  that  are  not  broken.   Tony  ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 9:26pm
Maybe, somebody put an early B engine in your CA! The engine number stamped on the block would tell.
