Engine CFM and thinking ahead
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: Engine CFM and thinking ahead
    Posted: 24 Jul 2019 at 9:17am
ok guys.  slowly working on my puller build and looking into carburetor requirements/mods that may be needed down the line.
A stock UM engine (318) at rated 1200 rpm and 80% volumetric efficiency(which is high im sure)  is 88 cfm.  not accounting other variables.
The industrial tractors had an optional 1800 rpm governor which comes out to 133 cfm
My build with 10% over factory ag tractor rpm at 1320 rpm comes out to about 133 cfm
These tractors used the zenith K5 carburetor. With a slightly massaged intake can i assume this setup would still be tuneable since the cfm is relatively the same or am i comparing apples to oranges here?  could we assume jet adjustments and/or a change to larger venturi would work?
I am diving into the deep end here and havnt been swimming very long.
Edited by CAL(KS) - 24 Jul 2019 at 9:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 7:47am
No opinions?  I realize this is kinda unknown territory here but if a 45 carb can feed nearly double the oem cubes surely the larger K5 can do what im asking here?  Not sure there would even be another option with the way the carb is operated from governor linkage anyway.
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 12:19pm
I have no experience, in tractor carburetion but, you math seems right and you should be able to set the A/F ratio for best power, if it has a external adjustment.
If you'd like a suggestion of how to get the A/F setting w/o a dyno. You can do that with a ox sensor.
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 12:50pm
good point. thank you, I will need to drag something around to load it as no pto LOL
This page was generated in 0.071 seconds.
