WD / WD45 Gas Tank?
SFSutton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SFSutton Quote  Post ReplyReply Direct Link To This Post Topic: WD / WD45 Gas Tank?
    Posted: 22 Jul 2019 at 6:35am
Are WD and WD45  (gas) tanks interchangeable?
Thank you
D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 6:50am
Yep
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 6:58am
WD and WD 45 are exactly the same.
WF and WC are the same as the WD, except the fuel outlet is on the right side. (Some tanks had gas outlets on both sides.)
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 8:58am
Ta might watch,, some of the early WD's did not have a dimple where the hydraulic rod gets close to the tank on the right hand side,, this change occurred when the rod to the pump changed size,, early WD have a 1/4" rod.....later ones (WD's) and the 45's have like a 3/8" rod
I don't know when this change occurred
This page was generated in 0.184 seconds.
