Building a 190 xt Powerdirector for pulling
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Building a 190 xt Powerdirector for pulling
    Posted: 20 Jul 2019 at 4:15pm
Is there any way to build a 190 Xt PD better to handle 250+ horses ? Will Kelvar clutch discs help ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 9:32pm
If the Power Director clutch is healthy( all related seals, sealing rings, discs and plates), and a 190XT or 200 ( not a 180-185-190) 250 HP should not be a problem with full stroke on the P.D. valve spool and the pressure set at 325 to 350 PSI in both LOW and HIGH ranges. My choice when rebuilding is always 70261212 friction discs from a 7000 tractor. They hold more HP ( at less hyd pressure) and never break/split.
