D-10 crank seal
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: D-10 crank seal
    Posted: 19 Jul 2019 at 8:50am
D-10 series III. Can the front crank seal be changed without pulling the timing gear cover?
Thanks,
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 10:26am
I don't know why not, if you can see it and get a self tapping screw, screwed into it in a couple places. I have a threaded rod that fits my vice grip, and a piece of round stock with a hole thru it. Put it together and you have a nice slide hammer for grabbing the head of the screw.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 12:55pm
It can be done, but it's best to remove it.  If the timing cover is not properly centered, that new seal will be finished in a few months.  I did the front seal on my D14 in the winter and removed the front cover, not a big job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 7:39pm
If you don't remove the cover, you need to somehow check crankshaft OD to the seal bore ID for concentricity. That would most easily be done by using a plug gage, with a bore no more than .002 over the crank size and the plug no less than .002 under the Seal bore size.
Edited by CTuckerNWIL - 19 Jul 2019 at 7:42pm
This page was generated in 0.110 seconds.
