Truck bed mat?
Neal (scMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neal (scMN) Quote  Post ReplyReply Direct Link To This Post Topic: Truck bed mat?
    Posted: 17 Jul 2019 at 9:19pm
What is the best to put in the bed of a new truck, rubber mat, spray on or carpet?
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 9:35pm
I have had bed liners they rust out the bed and you don’t see it till it’s too late. Used carpet when I was poor got spray on in the latest truck like it the best. Stuff doesn’t slid around
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 9:37pm
I have had a rubber mat, about 5/16 inch thick on the floor of my lasts 3 trucks.. Like that the best.. nothing slides and you can pull out and wash out twice a year.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 10:12pm
Name brand spray on, only way to go as far as I am concerned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 3:10am
If I can ever find a rust free bed to replace what my Pickup has, I’ll only go with a spray in liner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 5:38am
some stuff I know...
my '97 F150 has has a liner in the box ALL of it's life, ZERO rust from it being in there.
3 trucks next door,used for /landscaping/snowplowing had sprayin liners, all 3 rust rotted from top front lip down and other spots. All three now have new beds($$$$!!) and liners
How a bed holds up depends on what you haul, how often  and how you cleanup. Haul sharp gravel and shovelling it out will chew the factory off, so rust will begin. Haul bags of salt that bust...... the bad rust cycle will begin( and never end).
I look at sprayon bed liners like powdercoat, unless applied 100% right, over 100% of the box and allowed to 'cure' 100% before install, you've got 100% future problems.ANY knick, gouge, knife cut and water(especially salty water) WILL get in..then the trouble begins.
With a liner ,you can (with 2 guys), easily remove and inspect the bed. Aside from 'paint wear', mine's fine. A rotted out box with liner, to me indicates water from the liner got through a hole and sat in the box, because the drain holes in the box were plugged up.
In the end what kind of protection you add depends on what you use the box for. What I do know is that any box with a sprayon liner is NOT repairable.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 6:59am
As long as the do the correct procedure, I would never be without a spray in job.
Factory is el supremo. but i spose it is too late for that now.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 8:52am
Well there you have it!  The best is a spray on.  Except for liners. Except for rubber mats.LOL
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 10:47am
For what it's worth I have had a rubber bed mat in my 94 since new.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 12:03pm
½" Plywood with a 2x4 at the front (toward the cab) and hinged at the tailgate.  With the tailgate down, makes a flat surface almost to the end. Finished with two coats of machinery grey enamel.   Made for a 2007 Canyon, it is now in a 2015 Canyon. Great for hauling and sliding firewood.  Gets a little slippery when wet, and can be removed to clean.
R. Musgrave
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 4:46pm
I had Line-X sprayed in mine when new, then put a rubber mat on top of it. The Line-X is a little slippery and does not stop the bed from getting dented when, say, a heavy engine block tips off the pallet....ask me how I know
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 5:59pm
I have an 89 Chevy with a plastic bed liner since new. It is the only area where this truck has NO rust. My 05 Chevy, same thing. The 89 has 250,000 on it and got used hard. Also the plastic liner is ideal for using that Loadhandler as seen on TV.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 1:06pm
My 89 Jeep Comanche has had a plastic bed liner since new and I have not noticed that the bed shows any sign of rust when i have been under the truck. It is slippery and I usually tie down anything that might slide around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 1:38pm
put a topper on it
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 8:50pm
Rubber floor and plywood over it works for me, but we load with forklifts all the time and rubber alone doesn't like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 6:20am
put a topper on it
I hate toppers.  If I wanted a suburban, that's what I'd buy!WinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 6:26am
got a perfect 'topper' from an '04 SB Chevy, can't GIVE it away. even has privacy glass  all round, goin to cost ME money to take to dump...arrgh....
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 7:48am
Yea and as soon as ya do that some one wants it. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 1:02pm
no matter what you put in your truck box, make sure you have drain holes.
This page was generated in 0.171 seconds.
