electric drill's |
Brian S(NY)
Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3383 |
Topic: electric drill'sPosted: 16 Jul 2019 at 8:54pm |
my makita drill with manual chuck crapped out during a project and I have been trying to drill steel with my portable drill with the automatic chuck on it. The chuck keeps loosening up and spining on the bit.. :( and when you get almost through the darn drill doesnt want to finish the hole. Do they still make heavy duty variable speed electric drills with a manual chuck?
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 16 Jul 2019 at 9:20pm |
As bad as it hurts me to say this I bought a 1/2” drill at harbor fright. It has lasted since 2011. I GM have drilled lots of holes (25000) in 3/16” purlins on one job. It has mixed a lot of tile grout and a lot of drywall mud. It has served as an electric starter on 2 different welder motors. And it’s drove a whole lot of timber locks and lag bolts.
Brian S(NY)
Posted: 16 Jul 2019 at 9:43pm |
and it has a manual chuck? I'll head there tomorrow
Dakota Dave
Posted: 16 Jul 2019 at 10:31pm |
THe Dewalt titanium bits I bought have three flats and can't turn in the chuck there also sharp enough I can drill almost anything with an old B&D cordless drill.
Edited by Dakota Dave - 16 Jul 2019 at 10:32pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 17 Jul 2019 at 4:46am |
My favorite, right now is a ryobi cordless impact driver, with cheap HF unibit set. The unibit drills have a hex shank, that snaps into the QD of the driver. Still have an old B&D 1/2" manual chuck, for larger drilling, + a drill press, for the big stuff...
Thad in AR.
Posted: 17 Jul 2019 at 5:04am |
Yes |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Posted: 17 Jul 2019 at 6:20am |
yep my HF drills and favorite black and decker 1/2" that I cannot beat down all have manual chucks.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Posted: 17 Jul 2019 at 6:50am |
I will have to look in the storage unit. I have a Milwaukee, corded , electric drill with a manual chuck that I haven't used in over 10 years . Battery drills just perform too good . I have a corded electric sawzall that hasn't been hardly used in just as long .
The bits that have 3 sides and won't slip are the only ones to use on a speed chuck. |
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5175 |
Posted: 17 Jul 2019 at 8:27am |
We use 1/2" Makita drills in the chicken house to turn winches and have had to rebuild them a couple of times. You can get new brushes for them and probably other parts I'm sure. If it were me I'd look real deep into rebuilding rather than buying new
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4275 |
Posted: 17 Jul 2019 at 8:49am |
I HATE keyless chucks! They are handy but they suck all the same!
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 17 Jul 2019 at 8:57am |
But the keyless chucks are round, no jaw to grip the flat. The keyless chuck was supposed to be a safety inventions, so you didn't leave a key in a spinning drill. We're so safe we can't do anything now!
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 17 Jul 2019 at 9:47am |
See if you can get just a regular chuck. ---That's what I did to 3 of the old drills I was given because the keyless chucks were junk. I tossed the chucks in the junk and found good ones to put on them. All you need is to match up the the thread size and it will work.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4071 |
Posted: 17 Jul 2019 at 10:08pm |
i have a makita 1/2 18 volt drill , great drill use it very hard and almost daily i whent in to the makita dealer and we put a manual chuck with key , best thing i did, we replaced to many of the keyless chucks , if you spin one bit in a keyless chuck they are never very good from there on out
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 18 Jul 2019 at 11:38pm |
I realize they can slip but it sure nice to use the keyless chuck when you have to change bits a lot. For instance when drilling a hole in sheet metal then putting in a screw bit.
Allis Express participant |
Ken(MI)
Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
Posted: 19 Jul 2019 at 7:03am |
I get where you're coming from, my biggest complaint with cordless drills is the chucks. ButKeyless chucks aren't the problem, cheap keyless chucks are. I have a Milwaukee 1/2" corded drill we use to hone holes with (up to 18" diameter) fitted with a good keyless chuck (probably about $200.00 plus) and it works great. You get what you pay for. For that matter, cheap keyed chucks are no joy either.
