Antique tractor pull
aaronac1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaronac1 Quote  Post ReplyReply Direct Link To This Post Topic: Antique tractor pull
    Posted: 16 Jul 2019 at 4:35pm
Hey guys I'm thinking about pulling my grandpa's WD45 in the antique tractor pull coming up in a couple weeks never pulled anything in my life do you have any advice so I don't look like a fool? Grandpa's has since passed but always complain that there was never any Alice Chalmers pulling so I decided why not.
Wd-45 D-17s4 170 185 190xt 7045 8070
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 6:30pm
Try to get it weighed, with you on it. Then add weight, in the rear, to get it close to the max in the class that your closest to.
Run 10 lb max in the rear tires and talk to anyone, in your area, that has pulled your track before, especially in the class to you will be in.
Edited by frnkeore - 16 Jul 2019 at 6:31pm
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 7:50pm
In true field stock classes, the drawbar is one of the most important things that is relatively easy to alter to make a difference. Check your rules and get your hook as close and high as the rules allow.
Make some brackets on the extreme front and rear to hold additional weight. 100 lbs as far forward as rules allow can make as much difference as 500 lbs. in the middle of the tractor.
Watch the track in the classes before yours and see where the best traction is.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 9:28pm
First rule for antique tractor pull is HAVE FUN and remember grandpa !!!
