Remove wd pto shaft
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Topic: Remove wd pto shaft
    Posted: 15 Jul 2019 at 9:37pm
WD 45 PTO shaft is stuck to drop box shaft. It looks like the bolt got part way sheared off and is stuck TIGHT! What is the best way to get it to move? Rear bearing is bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 7:12am
Hook the PTO shaft to a real load and make it spin loose from the stub shaft. Then , pull it off.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 7:59am
Thanks DrAllis, will get with a friend that has a dyno . Should get a good load then.
