7060 alternator pulley
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 alternator pulley
    Posted: 14 Jul 2019 at 8:00am
Anyone have an alternator for a 7060 or
the double pulley for half inch belts.
I hate to say it but please don't recommend
All states ag parts as I have already called them
3-4 times about getting the pulley and have got no
response from them.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 8:53am
I may be wrong but don't the 7060, 7080, 7050, 7040, 7030 all use matched set of 5/8" belts? This is for both Delco and Niehoff alt's.
Pulley AC part #'s. Sorry but don't have the offset distances here.
Delco alt. - 70267872. 3.5" OD x twin 5/8" groove, .670 bore no keyway.
Niehoff - 70269548. 3.5" OD x twin 5/8" groove, .670" bore w/keyway.
Any shop working on farm, construction equip. electrical parts should be able to get you a pulley that crosses to these numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 7:53pm
Thanks.
The reason I need the pulley to begin with is
I have replaced the 3500 engine with a 3700 in my 210
and the 210 belts are different than the 7060 belts
and pulleys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 9:46pm
OK, the older AC's have used these sizes of 1/2" double pulleys. The biggest difference is the outset from alternator bearing, this helps aligns the belts. IF you have the original alt and mounts from 210 / 220 the first pulley may be what you need.
#70254832 on D19, 210, 220 not sure of Alt make. .670" bore, 3.25" diam.
#70256332 on 200, delco DB series alt. .670" bore, 3.125" diam.
#70260105 on 7000, not sure of alt. .670" bore, 3.5" diam.
#70260105 on 7010, 7020, 8010. not sure of alt. .670" bore, 3.5" diam.
