Check engine light
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Topic: Check engine light
    Posted: 13 Jul 2019 at 7:10pm
For several months the '99 F150 has had the check engine light coming on and showing mostly PO171/174 codes (lean condition on bank 1/2) along with a few other codes, reset and in just a few miles or maybe a hundred the light comes back on. While changing out the water pump, which was successful by the way, just for grins I disconnected most of the electrical connecters under the hood and put a dab of dielectric grease on them, been almost a week and no more check engine light, knock on wood (tapping on head). May be just dumb luck but thought I would post it on here in case someone else has that problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 7:15pm
Interesting ! I've seen them numbers before... I just 'reset' the computer. Years ago I replaced the MAS ( Mass Airflow sensor) and whatever code had come up  magically has never come back. I found out Ford uses DIFFERENT sensors  for 6es vs v8s !!! idiots....
oh well...
thanks for the info !!
Jay
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 10:08pm
oh well...
Earlier this year my son bought a 2007 F150 with the 4.6 V8. Suggested an oil/oil filter and air filter change as we didn't know the last time it was done.
2 oil filters listed that will fit. If the engine was built in Windsor Canada it took the filter with standard threads, if it was built in Romeo MI in the USA it took the filter with metric threads. Luckily the filters are a different shape/size so I could measure the filter to see what we needed.
You would think by the early 2000s Ford would have standardized something like this but then I remembered they made a 427, 428. and a 429 engine and 3 351s, a 351C, a 351W, and the 351M.
Edited by iowallis - 13 Jul 2019 at 10:09pm
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 6:32am
oh well...
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 6:33am
oh well...
 Chit,,Iowa,,,I'm stayin out of this one,,,,,LOL ole Shameless ,,he be on here in a little,,,,LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 7:13am
p0174 LEAN code can also be due to excess air (LEAN)....... on a 20 year old motor, you should check the vacuum lines for cracks / excess heat dry out/ brittle ........... pull them off one at a time and look............ on the FORD 5.4 V8, a good place to look is above the drivers valve cover toward the rear, there are two small hoses about 8 inches long and 1/4 inch ID that are connected to the EGR system... right by the exhaust manifold.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 8:08am
P0171 P0174 lean codes generally mean you have a vacuum leak. Dirty MAF sensor will bring up the same code. Plugged fuel filter will do it and a weak fuel pump. The PCV hose/line where it connects to the intake around the throttle body usually rots out from crankcase gases.
Steve (ill) is talking about the DPFE sensor I believe. The hoses connect to the exhaust manifold and measures EGR function. The sensor corrodes up internally and quit working. Won't cause a lean code though. If they are burnt up it's usually the converter is plugged on that bank and back pressure is causing it.
Hubert if you solved the problem by treating the connections....awesome. I can't really put it together yet but time will tell, it always does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 8:27am
steve, all the vacuum lines look good but I will double check them.
fixer, I can't put it together either but the codes on this thing will drive a sane person crazy, for me it's just a short walk.  Replaced the fuel pump about a year ago, was causing a no start condition but let it sit for a while and it would start right up. Forgot the code but it was seemingly unrelated, clear the code and it would start. Took a good Ford mechanic a week to find the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 9:29am
One often ignored component is the Vapor Recovery tank under the passenger inside the frame(sometimes). It has a life span where once the carbon is all degraded and used up becomes a vacuum 'Leak'. Will tend to smell like gas leak when just refilled as the tank vapors are just released.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 9:48am
we just put 4 new tires on our new burb, had street tread and I wanted mud/snow. and after doing so, it's check engine light came on and stayed on all that day. then the next day it went off and stayed off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 12:46pm
Shameless, it doesn't want to go out and play in the mud and snow!
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 5:51pm
Wink Sitting in the yard all the other computers whispered you better nice to Mr Shameless or he will park next to "the machine" .LOL Then you stay cold all winter under a big pile of "pretty". LOL An you never know where the dynamite them mad AC guys pitch in the yard will land,Wink their hands so cold from the pretty.LOLLOLLOL
