WANTED: Original set of HD6G Manuals.
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Topic: WANTED: Original set of HD6G Manuals.
    Posted: 10 Jul 2019 at 6:29pm
If anyone has an original set of manuals for the HD6G that they are whilling to sell please PM me. I know of the following manuals, but suppose there are others.
Operators Manual.
Service Manual.
Injector Service Pump manual - Bosh style PSB Pump.
I have also seen that some machines have two addition manuals. I think those are the Driveline Service Manual, and a separate service manual for just the AC 6000 & 7000 engines. I do have the AC 6000 motor, but im not sure if the HD6G required a separate manual for that.
The serial numbers stamped on the dash are:
Tactor - "HD6G-16302"
Engine - "6-17208"
I am not able to confirm if the engine stamped serial number matches because I don't know where it is stamped.
Note: I have a HD6 Parts Manual that I got free off the internet, but it does not mention the AC 6000 motor or wet clutch. Just the buddha and two styles of dry clutch. Do the HD6G manuals menton the newer motor and wet clutch, or were those possibly retrofitted to the machine at some time in the past.
I also have a Hd6,HD11 steering clutches and brakes manual published in 1989 that I also got for free from the internet. Not shure if the HD6G manual does, or does not require that seperate manual or not.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 7:39pm
For the moment try the on-line parts manuals at Minnpar
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 10:18pm
HD3
