Wd ..... Kinda 45?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: Wd ..... Kinda 45?
    Posted: 10 Jul 2019 at 4:14pm
So I found a different tractor locally that has a wd45 sticker on the front but the current owner is the second owner of this tractor and says sometime about 20 years ago they put in the 45 horsepower kit to take this tractor which he claims to be a wd up to a class of tractor that is 45 horsepower making it the same as a wd45...
It's pretty clean looking good tires and rims all around he claims everything is in good working order but the serial number is confusing to me if it is actually an older WD and not a wd45...
He claims the serial number is wd244851.
Looking at the serial number chart that would be hey wd45 unless I'm looking at it wrong?
Edited by Hunt4Allis - 10 Jul 2019 at 4:16pm
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 4:39pm
That might be the "engine" serial number.
The last WD-45 built in 1957 was  tractor #WD236958.
The usual "kit" to increase HP was simply 1/8" oversize pistons.
To make it as powerful as a WD-45, the crankshaft with a 1/2" longer stroke
would have to be installed
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 8:17pm
Most WD's had a straight shifting lever and straight cut gears. Starting in the late WD's and all WD45's had a curved shifter and helical gears.
WD's were 201 cubic inch. WD45 were 226. As Brian said, the WD45 had a 4.5" stroke compared to 4" for the WD.
WD's had a 3" head. WD45's had a 4".
Unless the crankshaft was changed, you will not have as much power as a WD45.
Serial number is on the left rear of the rearend. Sometimes they are hard to see, if they have been painted over.
Edited by WF owner - 10 Jul 2019 at 8:19pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 3:11am
Well you are talking about a tractor that could be about 70 years old,a lot could have happened over the years the current owner doesn't know about and memories fade.
Also when buying tractors take things like 2nd owner with a grain of salt.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 5:35am
The last WD was serial 146606. The first WD-45 was serial 146607.
Around serial # 83000 WD got the 4" head.
Serial 127xxx and later WD's had the curved gear shift.
It is possible to put a WD-45 crank into a WD block.
If there is a plate on the side of the right side of the block,
it started life as a 201 engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 6:57am
I agree after having 5 of these I have seen all kinds of changes and fixes that were done prior to me getting them. Both the WD and the WD45 are good tractors. Both will do work.
Look for the features such as Calvin mentioned. At this point the innards could have been changed several times.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 7:14am
The "kit" was probably a WD45 crank and pistons.  60+ years after they were made, who knows what has been done to them.  Without a teardown or deep inspection, you only have guesses.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 7:29am
To even be considered to be a WD45 clone, it must have the later transmission with the curved gearshift. This happened at chassis sn 127,000 or so. The engine got a different crankshaft, pistons, intake/exhaust manifold, carburetor and air cleaner over the last WD's built. The engine block was also changed, but that had nothing to do with making the extra HP. The later WD's also had the tall cylinder head already and that had little to do with the HP increase. There have been many claimed to be a "45" engine, but usually fall short of the 5 things I listed that was involved in taking the HP from 34 to 43 at the PTO.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 7:47am
A wire down the spark plug hole will help. 4 inch travel = WD 4-1/2 inch travel = WD45
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 4:02pm
ecosystem fauna mammal cartoon vertebrate horse like mammal
John (MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 7:11pm
Buying a 70 year old tractor based on what the current owner tells you would be a mistake. Unless they overhauled the whole thing themselves in the last 5 years, you can bet they will be wrong about something, if not most everything. Good thing is we aren't talking about something worth tens of thousands of dollars. Buy based on what you can verify and assume everything else is as bad as it can get.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 7:27pm
It's not going to matter unless you plan on really making the tractor hunker down and work. It does matter a little when it comes to price. It matters if you plan on overhauling the engine. You'd probably open it up before ordering parts anyway.
As for collector's value, if the serial number says it's a WD, it's a WD, regardless of what has been done to the engine.
Edited by DougS - 11 Jul 2019 at 7:29pm
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 8:15pm
This is great info. I have two WDs. SNs are around 138XXX and 141XXX, and both are curved gear shifter models. Anything else that is closer to "WD-45" in them than straight WD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 8:59pm
The '45 has more plates in the hand clutch, I believe.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 9:14pm
I love you guys and all of your great knowledge!  Smile   Just got home after using my 1955 WD45 to pull a roller over the grounds at the local historical society this evening.  Yes, these old tractors still perform useful tasks.  And yes, they're still fun to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2019 at 7:20am
Early WD-45's had the 2-plate hand clutch and 6 spring pressure plate on the foot clutch. These were items that were upgraded in later tractors to 3-plates and 9 springs.
This page was generated in 0.436 seconds.
