What is it |
Post Reply ![]() |
Tractor 1 ![]() Bronze Level ![]() Joined: 09 Jul 2019 Location: Jasper indiana Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jul 2019 at 8:15pm |
I bought a B or C I'm assuming .
The Serial number is 78579. Can anyone help. Thank you !! |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7506 |
There should be a letter before that number. Serial number is just in front of the gearshift. Should read "Tractor No."....
Robert Mull Sr Georg ![]() Bronze Level ![]() ![]() Joined: 12 Oct 2017 Location: WOODSTOCK Ga Points: 17 |
If the steering arm is pointing up out of the steering gear box it is a C if pointing down it is a B
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
It is not uncommon to see a C with a B transmission and vise versa
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
The shop manual that has sections for each might help identification:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2678 |
Maybe post some pics of the tractor. Lots of folks on here will ID it real quick then.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5026 |
A B is narrower (rear wheels) than a C.
Thank you !
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87949 |
A "B" will have a gear box under the gas tank with the arm down as noted.. A "C" will have a gear box under the gas tank with the arm UP and steering rod run to a second gear box under the radiator... The front wheels of a C can be narrow or wide front end, but always driven from this SECOND gear box.
Thank you !!
It's a B then. I appreciate it |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54167 |
1949 model, if its a C...
Post Reply ![]() |
