Engine overheating conundrum
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Engine overheating conundrum
    Posted: 08 Jul 2019 at 10:13pm
Spent the day working on my daughter's car. It is a 2003 Mercury Sable LS with dohc 3.0 liter engine with 128,000 miles. Replaced the thermostat, temp sending unit and the water pump. I believe I have all the air bled out of the system. Still wants to blow water out of the reservoir by the time I drive down the road about a block to pull on the highway. Get down the road a mile and turn around and it temp gauge heads for the red.
Anybody got any ideas what to do next. Google hasn't been much help. Did find one article that mentioned defective reservoir caps from factory.
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 11:17pm
Blown head gasket or cracked head????
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 3:23am
plugged exhaust
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 5:27am
Do you have one of those IR heatguns? Best $20 I ever spent! You can 'point and shoot' and get local temperatures....
Maybe the rads plugged ? it should be warmish all over, the IR gun will show .
Stat in wrong way, or defective..stuck stat  can cause problems....
'bleeding' might be a painful proceesdure. I've heard some cars have TWO bleeders in the block...
I'm surprised Google didn't find anything. should be good news...nothing 'serious' but PITA for you
I'd check stuff, refill, keep cap off, run good 20-30 minutes in driveway to get good n hot, check level and temp of rad water.
New rad cap ?? maybe it's bad ??
sorry, got no more rabbits in my hat....
please post WHAT did cause it though ,when fixed.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 6:57am
For now ruling out head gasket for now, as no exchange of oil or water noticed. Doesn't sound like this engine is really known for that. Might pull thermostat to double check I have bleeder at top. Luckily this uses an o ring instead of a gasket. Gonna try flushing the radiator next. Thanks for the input. Keep it coming.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 7:19am
Another quick check on head gasket, is feeling for pressure on the radiator hose, could be pumping exhaust gas into the rad, and you can feel the pulses in the hose and/ or the pressure.  You probably knew this.  Can you run it with no thermostat at all, (I'd think so).  Can you check the heater core?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 7:58am
hmm..heater core ! could be a big slug of air in that line depending on how it's 'plumbed'. turn heater on ,see if it gets hot or warm, check hoses in and out,should be warm/hot...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 1:22pm
If it has electric fans, make sure they're working. May have to replace the Radiator. POS plastic Radiator is probably plugged.  My cousin just replaced his with about the same  mileage as you have in his Malibu.  He changed the stat and so on,  and wound up tossing a Rad in it.  Done deal. Behaves itself in the hottest weather with the A/C on......
Steve@B&B
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2019 at 11:22pm
I had a blown head gasket that acted exactly the same. No mixing of water or oil either. Thats because combustion gasses are bleading into the water jacket.
99% sure its the head gasket. New cars with iron blocks and Aluminum heads don't need hardly any overheating to do this.
Pull each spark plug one at a time. One or more of them will be nice and clean. That's the cylinder thats leaking combustion gasses into water jacket. Usualy the ones in the middle of the head.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 6:18am
My bet would be a warped head.
Fill it with coolant and let it run with the cap on till the pressure in the cooling system
makes the hoses hard and the engine is almost to the point of overheating.
Shut it off and let it sit for awhile and cool some. If it idles rough on restarting you have coolant seeping in a cylinder.
Another alternative is to take it to a shop that has an exhaust gas analyzer and check for hydrocarbons being emitted from the radiator (or where ever you fill point is).
Anything over 75PPM hydrocarbons is a sure thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 6:49am
This one has cast iron heads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 7:13am
Doesn't matter. May be a little tougher but still not immune to warping. The only difference may be that it will crack. Mostly between the valve seats.
Then again it may not be warped and it could have some erosion around the water jackets of the head gasket and over heating finished it off. Doesn't necessarily have to get coolant in the oil.
Another erosion point on the particular engine is the timing cover gasket. The timing cover will be pitted and the gasket blown out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 10:29pm
Plan on doing a pressure test on it in the morning. Flushed the radiator tonight after work, and didn't find anything. Starting to think it could be a head gasket.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 10:05am
speaking of rads.  Any decent rad shop can flow test a radiator.  i don't think just flushing will cure a toasted rad, but I think a flow test should show whether it is flowing as it should.  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 5:58pm
I'd do the exhaust gas test, in the radiator neck, quickly will rule out if its a HG, or not, so you can move on to other things
[TUBE]x2f5qEhaFdk[/TUBE]
Edited by DiyDave - 14 Jul 2019 at 6:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 9:06pm
Darwin, my first thought was just like Baverwolf says, head gasket or head.  I had a 68 Buick Skylark that gave me fits just like you're having.  Found that the head was warped.
Good luck!  See you at Hutch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 9:32pm
Gonna stop by mechanic after work tomorrow and we what they get to do head gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 9:51pm
I have had REAL GOOD LUCK with a sealer called BARS COPPER HEAD GASKET SEALER..#1109 .... You pour it right into the antifreeze and run a little to build up pressure ... shut motor off and the pressure pushes it into the crack head or gasket... Let it cool overnight and startup and run a couple miles tomorrow and shut off again... I did this on a F150 5.4 V8 and ran another 50K miles with it..... I pour a cupful into a couple "B" motors that had either head gasket or liner o-ring leakage and it fixed both.  ( not freeze plugs in head).
Edited by steve(ill) - 14 Jul 2019 at 9:51pm
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2019 at 9:35am
That Copper head sealer is good stuff.  I've used it successfully on a couple of engines that have had leakage problems with those new style composite head gaskets.  They's not near as good as the old copper sandwich type!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2019 at 12:21pm
steve(ill)  "I pour a cupful into a couple "B" motors that had either head gasket or liner o-ring leakage and it fixed both.  ( not freeze plugs in head)."
Steve it says it will work for freeze plugs in the second sentence on their product page for the BARS COPPER HEAD GASKET SEALER #1109
https://barsleaks.com/product/liquid-copper-block-seal-intake-radiator-stop-leak
Good info if in a bind time wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2019 at 10:04pm
I thought about adding a bottle of Mendtite, (I've had excellent results with it fixing water leaks), but the pressure is going the wrong direction.
Talked to mechanic tonight. Estimated cost of $1500-2000, so repair is out of the question.
Willing to make someone a heck of a deal on a low mile Sable with a nice bdy and excellent interior. And a 95 Monte Carlo with high miles and a blown head gasket.
This page was generated in 0.184 seconds.
