Hd5g counterweight
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: Hd5g counterweight
    Posted: 07 Jul 2019 at 9:37pm
I have a hd5g that i just finished restoring. I have been working it without the counterweight and noticed it is very much needed. Has anyone put 2 counterweights on? I am ready to put the first one on, wondering if a second one is needed. I do have another, slightly smaller. Thanks
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2019 at 10:00pm
I think 1200-1500 pounds is about right, according to what I have read and been told
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:23am
Ripper is just enough, backhoe is too much!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 10:13am
I would love to find a ripper. Anyone have an extra?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 11:11am
The large Iron block on back of my 7G is estimated at over a ton.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 10:46pm
My HD5G has 2 counter weights on it - a larger thick one inside and one about 3/4 thickness next on outside - both have a rod cast into top of cutout for lifting them.
 Two weights I would say in many cases is a little light if working heavy soil - but for most use with the 1 yard bucket it's OK . Backing up in soft ground with bucker about 2 ft high it will tend to transfer weight to front idler so keeping bucket low when reversing is best .
 Problem now is most new trucks have high sides and unless you dig a depression for them to back into you neen a ramp to load them .
 So now if loading I use the AC 715B TLB .
Edited by Coke-in-MN - 17 Jul 2019 at 10:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 10:48pm
The 2 weights on my HD5B
