bobcat 743b problem
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: bobcat 743b problem
    Posted: 07 Jul 2019 at 9:19pm
anyone in Missouri have any mechanical knowledge on a bobcat 743b. have a seal leak on my rear left tire. see theres a black plate located between the tires. wondered what it was for and how to get it off. pm if you do so I can call you . thanks norm
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2019 at 9:40pm
If it’s an axle seal you will need to open the chain case and remove the drive sprocket to slide the axle out of the wheel side. Kind of a major project
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:26am
Try this question over at Heavy equipment forum, lots of info, over there...
