Simplicity question? |
john(MI)
Topic: Simplicity question?Posted: 05 Jul 2019 at 10:52pm |
It's not a garden tractor, it's my Simplicity, Courier Zero Turn. Has anyone figured out how to put a decent hitch on the rear? Thanks
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 06 Jul 2019 at 6:54am |
I tried to see what the back looked like, not a very good rear view in the add.
How heave is the metal on the back side? Would it matter if some of the slots were covered? Dusty
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25179 |
Posted: 06 Jul 2019 at 7:09am |
I checked 'partstree.com' for a good look... That black bar is lightly attached to the red sheet metal that's lightly screwed to the stamped 'frame'. I'd start with angle irdon BOLTED to the sides of the frame(on top of the U-shaped red rear piece), then some vertical steel under the black bars, on top of the red sheet metal. Probably take all day ,cuttin and fittin and cussin, but it could be done. First one's hard, 2nd and 3rd ones easy..well, easier. Jay
john(MI)
Posted: 06 Jul 2019 at 11:25am |
The tin guard is somewhat substantial, but I don't know how thick. I don't think it would matter if a couple slots were covered. It's mainly a safety shield around the muffler.
Dusty MI
Posted: 06 Jul 2019 at 12:05pm |
Then maybe a heavy angle iron with a couple large steel disc for washers or tapped and used as nuts, with bolts, thew the slots.
