The B TDC on a cylinder
2011dandd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Topic: The B TDC on a cylinder
    Posted: 02 Jul 2019 at 1:55am
Hi guys
I had some trouble with hot starting the b then starting it at all so I have had the magneto rebuilt.
Only thing is I forgot to check which cylinder the rotor arm was on when I took the mag off.
So I’m asking for a fool proof way of knowing that number one cylinder is at tdc and not 180 degrees out, without taking the bonnet and rocker cover off.
Cheers guys
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 5:49am
#1 piston at the top, and the word “center” visible through the inspection hole on the left side of the bell housing. If you want to be super extra sure, take the valve cover off and both rocker arms on cylinder #1 should have some free play, in ther words, not pressing n the valve stem.
1951 B
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 6:31am
#4 will be at the top the same time as #1, so you can't go by the mark alone, you need to be sure #1 is at the top of the compression stroke. #4 should be just completing its exhaust stroke at that time. If #4 is on its compression stroke you will be 180 out.
Remove all 4 spark plugs. You (or a helper) can hold a finger or thumb over the #1 sparkplug hole but if you have or can borrow a screw-in compression tester it will be easier to watch while you crank the engine over. Install the tester in #1 cylinder. Crank the engine over and watch the gauge. It should show pressure building as #1 comes up getting ready to fire. Once you see the pressure building watch, in the timing window, for the TDC/CENTER mark on the flywheel. When the mark is centered in the window you should be in the correct location. My thoughts, others may do it differently.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 12:11pm
It has to be TDC on the compression stroke a Jim said.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 12:41pm
There might be some help in the shop manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 1:48pm
Cheers guys. I was being lazy I think I will be much better off taking the bonnet and rocker cover off and getting the valve position right to get tdc.
Cheers
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 6:32am
Cheers
Dan
That's a complete waste of time, when you can get TDC of the compression stroke by removing number 1 plug and feeling for compression as you turn it over.
 Unless you are in need of replacing the valve cover gasket that is!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 9:18pm
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 2:13am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 12:33am
Leave the bonnet on, Dan-  finger over the plug hole takes but 20 seconds...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 3:31am
Sorted
I did take it all off
Not a waste of time in my opinion. At least that way I can watch the valves and know when I’m on tdc and correspond it to the fly wheel fire mark.
By taking the plug out and feeling the build up of pressure/air I can’t be sure on what stroke I’m at
Anyway it’s sorted now
Cheers guys
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 9:34am
Give it the finger test. It worked on the UC when I did the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2019 at 9:57am
Sorted
Cheers guys
 When your exhaust valve is open on the upstroke, there is no pressure building up like when the compression stroke comes up with both valves closed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2019 at 1:55pm
Of course that makes complete bloody sense.
Any way folks for the moment it’s running sound and starts up lovely
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2019 at 6:14pm
2011dandd,
Awesome! Sometimes it nice to know how things work too.
