Steering clutch; HD9
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: Steering clutch; HD9
    Posted: 29 Jun 2019 at 9:04pm
Friend of mine has an HD9 dozer that he says one steering clutch is a little sticky. Is it of the type that you can fill the clutch housing with diesel fuel and then run it for a little bit, then drain it out. Then put some solvent in and run it again, then drain it out...? Thanks, Darrel
