7080 Air conditioner quit
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: 7080 Air conditioner quit
    Posted: 28 Jun 2019 at 5:44pm
Have power to clutch when switching thermostat on and off, clutch isnt activating - charge was good on compressor earlier this spring. 95 degree day here when it quit. Any ideas? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 5:48pm
Its a R134a Everco A6 model.
Clutch and compressor are spinning as well
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 8:45pm
Either the coil in the clutch is bad or there is no ground, The second wire on the connector is a ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 8:53pm
Checked the black ground wire that goes to the front of the radiator to a bolt ground, wire looked good, it does go through some sort of resistor before going to the bolt - any idea if that would cause an issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 8:57pm
There is a ground wire in front of radiator left side. Bolt screws into frame where antifreeze gets on it and causes rust. Clean up good use new bolt and antiseze.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 9:01pm
Bolt head looked fine but i didnt take the bolt out to see if there was a rust issue. Will check tomorrow. Thanks.
