2000 GMC electric motor keeps running |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: 2000 GMC electric motor keeps runningPosted: 21 Jun 2019 at 5:00pm |
My truck has an electric motor that keeps running. It bolts to the frame left of the transfer case. It looks like brake lines going to it.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 21 Jun 2019 at 5:20pm |
If that is brake or ABS related have you checked the brake fluid level?
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90845 |
Posted: 21 Jun 2019 at 8:16pm |
Steve M Ind
Bronze Level Access
Joined: 12 Sep 2009 Location: Springport IN Points: 69 |
Posted: 24 Jun 2019 at 8:52am |
The relay is built into the ABS box. The relay is stuck on and needs replaced or it will run the battery down. Need to replace the controller part of the box. Have seen this many times.
DaveKamp
Posted: 25 Jun 2019 at 10:48pm |
My '99 Chevy had same thing happen, but the ABS pump kicked on, blew the rear brake line out, and totally emptied the master cylinder... At 45mph... With a flatbed trailer in tow... with 4600lbs of lumber on it... ...heading for a stop sign.... at a 2-way intersection... ... with two tractor-trailers full of grain coming one direction ...and a five-axle dumptruck full of gravel coming the other way... I was fortunate to have presence of mind to slap the trans into LOW, then grab the trailer brake controller and squeeze it to full, while flipping the GAIN switch to max... I got stopped about two feet into the intersection... all three drivers saw my trailer tires smoking and knew what was up... they moved over JUST ENOUGH to keep me alive. Cost of replacing that ABS pump (after lifting off the cab) was seriously in excess of the value of the truck, so away it went.
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 26 Jun 2019 at 5:03am |
Hey Dave Kamp,,,glad to see you safely back home from the Great Southwest snake country,,,,, ![]() ![]() Dang,,that sounds like you had you a close call,,!! You know,,them vehicles always seem to gain speed when them brakes fail don't they,,,?? There may be one of them trks up for sale up around the Eurica Springs area,,,,,,
,,Chit,,I'm outa here,,,,, |
Thad in AR.
Posted: 26 Jun 2019 at 5:16am |
I checked the fluid and it was ok. I drove it around the place and the brakes work fine with it unplugged. I haven’t had much time to mess with it.
Steve M Ind
Bronze Level Access
Posted: 26 Jun 2019 at 8:13am |
You can unplug it or just pull a fuse, Will not have the ABS function but will have normal brakes and the pedal should feel normal.
Thad in AR.
Posted: 26 Jun 2019 at 10:25am |
Is it safe to drive to work? They feel fine. |
Steve M Ind
Bronze Level Access
Posted: 26 Jun 2019 at 3:16pm |
Some of my customers never fix them. Just drivem with the ABS light on.
