7045 transmission fluid? |
cwbristow
Joined: 19 Jun 2019 Location: Thomasville, NC Points: 4 |
Topic: 7045 transmission fluid?Posted: 19 Jun 2019 at 11:39am |
Where can I find a list of compatible fluids for this tractor?
My father just bought one and they told him that 821XL transmission oil would go in it, but it is $90 a bucket. The other they recommended is foaming real bad.
LB0442
Posted: 19 Jun 2019 at 4:00pm |
Any tractor fluid that has the meets 821 spec printed on the label will work. I prefer a name brand oil, there are a lot of universal fluids that people have had good luck with out there though.
The trans and differential have 2 different fill points and check points. If you are looking at the sight glasses when it is running they do normally show some churning/air in them. Never had one foam up in the trans, could be way overfull. Welcome to the forum. Pictures are always welcome.
DrAllis
Posted: 20 Jun 2019 at 7:17am |
Interesting. How do you even know that it is foaming real bad ?? And what problems is this causing you ?????????
Edited by DrAllis - 20 Jun 2019 at 7:17am |
cwbristow
Posted: 20 Jun 2019 at 8:12am |
It's bubbling so bad is looks like a cotton ball is stuck in the sight glass. Then it clears out in 20 mins, but I know that air is running through the gears and pumps till that happens. The old oil that was in it never did that. It was old oil that was in the tractor when he bought it.
DrAllis
Posted: 20 Jun 2019 at 9:33am |
Well, if the hydraulic pumps aren't making any unusual noises and are performing fine, you are speculating on a problem that may not even exist. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: 20 Jun 2019 at 10:05pm |
In my experience,you can't tell much about the rear end oil in the sight glass once it's running. It will appear low while it's not. You will see foam in the upper as well. That's why the book says to let it set for 15 minutes before checking sight glass or before startup on level ground.
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Posted: 21 Jun 2019 at 5:20pm |
$90 a bucket oil maybe cheap if the $20 bucket oil leads to part failures. Every tractor I buy gets new 821 oil and filters so I know what’s in it and it’s what is recommended. I had first gear seize to the shaft on a 7060 that was full of yellow bucket oil, and a 8970 New Holland that the top bearing went out and ruined every gear in it. Not saying the oil caused it but I won’t use anymore of it. Hurts more when you blow a hose though.
