190 puller
Bobo Husker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Topic: 190 puller
    Posted: 19 Jun 2019 at 9:47am
Hoping for some advice. Completed a-pump installation on 190. Works great however when I pull, I'm getting a crazy bounce. Some ole timers said not enough tire pressure, I'm running 13 psi on Good year dynatorques. 18.4r38. Some said try dropping hitch 1/2" and also could be clutch. I'm running an Atlas 11" double disk. I use 7th gear.
Any thoughts would be appreciated.
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 12:03pm
Sounds like power hop to me, Not balanced correctly
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 12:04pm
My thought's are, to much pressure.
More air pressure will give you less of a contact patch and you'll spin earlier. Not good.
Less will give you, more contact and have less energy to bounce. I believe that the only way to start a bounce, is to have slippage, first.
Sometimes, problems can be diagnosed with extremes, see what happens at 8 lb.
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 12:34pm
radials?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 1:02pm
Yes radials. It starts in front till whole tractor will bounce.
Allisplumber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 2:20pm
I would say try less pressure in the rear tires, a flat ball doesn’t bounce, I have better luck with my 200 with the tires softer and have enough weights to move around to balance it out , do you have a center weight bar , weights in the middle seem to do better, just my opinion
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 2:56pm
I do have a weight bracket in front of rear tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 7:22am
Weigh the tractor as you have it.    If it weighs 6000 lbs, I would try 2000 lbs on front wheels and 4000 lbs on the rear wheels AS A STARTING POINT.  Also, shift it into road gear and see if the clutch slips or kills the engine. That will diagnose that issue. Sounds like you are too heavy on the nose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 10:07am
I have to weigh 6500# total. I'm in 7th. Its 20mph pace.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 12:10pm
So it looks like 4400 on the rear and 2100 on the front.
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 7:44pm
I run 13-14psi and seems to work good. Firestone 23 degrees. Narrow tire stance with tires an inch from stock fender location. 190 a-pump 7th gear also. 6500lbs, I run with no weights and no bounce. 7500lbs 3-5 weights on front the rest on the back. Before I removed power director had a lil bounce off the line up to maybe 100 foot line but none on the other end. I'd try different tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 2:16pm
Yup I dont run PD either. I'm going to try hitch height alittle lower first. I'm weighted pretty much as Dr Allis suggested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 2:33pm
Goomer-what do you run for a clutch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 2:50pm
Stupid question, how do you run 7 th gear without a Power director?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 5:37pm
Coupled straight to low side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 7:56pm
Ok Gottcha, thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 9:52pm
I run a 2 disc kennys pulling clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 10:24pm
Got ya thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 8:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 8:49am
Dr Allis, I moved weight back. Helped alot. Seems like still abit front heavy? Taking notes for next year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 5:57pm
In the video, it looks like you have 250-400 lbs on the front ??  Too heavy in that run as it never picked up the front wheels once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 6:05pm
I had 400 on front 200 on belly. Makes sence though. Think I need to find some 75lb weights. Thanks again!
