B carburetor ?
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: B carburetor ?
    Posted: 18 Jun 2019 at 1:29pm
Is there a difference in a marvel schebler carb off a 49 B and a Zenith carb off a 39 B?  Can they interchanged?  Thanks!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2019 at 4:52pm
They are inter changeable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 2:22pm
39B won't start with hand crank.  Switched carburetors between 39 & 49 B's, 49 runs fine with the 39 carburetor, but 39 still does not start.  After a few turns with hand crank gas will drip out bottom of carburetor.  Need some advice or ideas on what to check.  Thanks!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 2:28pm
Each hand crank tractor seems to have it's own preferences for starting procedure!Wink.  My '39 B with Zenith carb likes gas on--one pull over with full choke, then choke off and one more pull over and it's usually running.  Depending on outside temperature, I might have to add a little choke 'til it warms up a little.
Too many cranks with the choke on will usually flood it and then it can be a devil to start!!
Edited by Alberta Phil - 19 Jun 2019 at 2:29pm
