hd3 for sale has few problems
cssminer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cssminer Quote  Post ReplyReply Direct Link To This Post Topic: hd3 for sale has few problems
    Posted: 12 Jun 2019 at 10:21am
I found an early 1960s Allis Chalmers hd3 for sale. It runs and opperstes pretty good. Reverse and turning is strong forward seems weeker. The tram lever pushes formard about 6-8 inches before it engages. in reverse it engages after around 2 inches. Can the clutch be adjusted?
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 2:24pm
It is a clutch pack adjusted by removal and installation of shims on the bench.  You split the tractor to remove it.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote cssminer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 7:54pm
Thanks. It seems to still have a little power in forward just week. Do you think it would still be usable for some lighter work for just a week or 2? Or should I plan on putting more money in it. If so does anyone have a ball park on about what it would cost to fix it.
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 9:01pm
first thing to do is make sure its in 1st gear. lose a lot of power in higher gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cssminer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 9:21pm
The guy who is selling it seems to know quite a bit about it and he's the one that was telling me it's weak when going forward. I don't know a whole lot about any heavy equipment. when you push the tram lever forward it goes 8 to 10 in before it starts to engage is that normal I know it won't be the same. Reverse only has to go a couple inches? Is there a way to adjust the linkage maybe it has slipped loose a little?
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 9:30pm
I am located 5 miles from Williamson WV. and could help if not too far away ?
where you located ?
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 9:40pm
Reverser looks like this I hope
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 9:41pm
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote cssminer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2019 at 7:43pm
I live in Beckley. I haven't bought it yet. I was trying to figure out if it is worth it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2019 at 11:51pm
any pictures ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 12:22am
Shimming that clutch is easily done in chassis on a farm tractor. Is that not possible on the dozer chassis ??
This page was generated in 0.142 seconds.
