What head gasket to use in 262
BrianOldham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianOldham Quote  Post ReplyReply Direct Link To This Post Topic: What head gasket to use in 262
    Posted: 10 Jun 2019 at 11:29am
Hello, I have a 1964 gasoline D19 with a 262 that has had LPG pistons put in it in the past. I'm currently replacing a damaged piston and sleeve and was wondering that since these LPG pistons are higher compression, what head gasket would be best to use when putting it all back together? What brand and application? I've seen that the Diesel ones are thicker.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 12:03pm
Pretty sure Gas and LPG use the same head gasket. Piston pin location is the difference in compression ratio.
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 12:13pm
pn  gas gasket 74514396  pn lp gasket 74514397
This page was generated in 0.107 seconds.
