HD4 steering clutches
stan ures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stan ures Quote  Post ReplyReply Direct Link To This Post Topic: HD4 steering clutches
    Posted: 09 Jun 2019 at 5:48pm
HD4 steering clutch box continues fill
With oil, hydraulic fluid why?? Going nuts!
Post Options Post Options   Thanks (0) Thanks(0)   Quote stan ures Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 5:49pm
Left side of seat
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 9:42pm
sounds like the oil seal between the rear end and final drive is destroyed and allowing the thin oil into final drive which is a dry clutch system. have you been having to add oil to tranny, torque tube , or Hydraulics ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 9:59pm
transmission oil or final drive ?
OR do you have a hydraulic leak from eithe fwd/rev cotrol or the oil tank for hydraulics .
 Open the top of steering clutch compartment , clean with a degreaser - then check for leaking oil again
This page was generated in 0.293 seconds.
